免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → OPTIMESS S1 CCD
产品名称: OPTIMESS S1 CCD
型 号:
价 格: 0.00
品 牌: OPTIMESS
The opto-electronic sensor OPTIMESS S1 CCD is a device for no-contact distance measurement.
This sensor distinguishes itself by a great independence of the measurement accuracy on different material surfaces and from the ambient light.
The OPTIMESS S1 CCD works according to the triangulation principle. The laser spot projected by a laser diode via an optical system is represented at an angle on a CCD line by a receiving optical system. The processor integrated in the sensor processes the optical distance information and outputs them as an analog value or via the CAN bus.
     Dynamic contour measurement
     Distance measurement, position control
     Profile measurement
     Thickness measurement
     Steel industry, industrial automation
     Rubber and tire industry
公司名称: 瑞士ELAG电子有限公司北京代表处
电 话: 010 51285271 / Sandy Zhang
手机:
地 址: 北京朝阳区酒仙桥中路26号丽港2号楼1702室
邮 编: 100016
主 页: http://www.optimess.cn
  • ELAG OPTIMESS®激光三角扫描仪-接触网测量系统
  • 车轮踏面轮廓在线测量系统--OPTIMESS®激光传感器
  • 瑞士OPTIMESS铁路/轮对/接触网/钢轨磨耗测量系统
  • 水平度测量
  • 抗强太阳光干扰-OPTIMESS®公路平整度和纹理测量系统
  • 抗强太阳光干扰--OPTIMESS®公路路面车辙测量系统
  • 偏心率测量
  • OPTIMESS MR CCD
  • 车轮踏面轮廓测量-------OPTIMESS®便携式激光测量仪
  • 轨道叉道段测量
