Form Factor |
3.5" SBC (146 x 101 mm) |
CPU |
Intel® Core™ 2 Duo ( Merom ) processor @ 800 MHz FSB |
Memory |
1 x 200-pin DDR2 533/667 SO-DIMM up to 2.0 GB |
Chipset |
Intel® GME965 & ICH8M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1Min/Sec ~ 255 Min/Sec |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
PCI Enhanced IDE |
1 x Ultra ATA/33 IDE channel up to 2 ATAPI devices |
VGA Interface |
Intel® GME965 integrated GMA (Graphic Media Accelerator) X3100 Technology |
Video Memory |
Up to 384 MB shared with system memory |
Serial ATA Interface |
1 x Serial ATA II Interface with 300 MB/s transfer rate. |
Audio Interface |
Realtek ALC888 HD Audio |
LAN Interface |
1 x Intel® 82573L Gigabit Ethernet |
Solid State Disk |
IDE1 supports 44-pin DiskOnModule +5V power supply
CompactFlash Type-II socket on the solder side . |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
1 x Min-PCI socket |
External I/O Port |
1 x RJ45 LAN ports, 1 x DB15 VGA port, 1 x HDTV, 1 x HDMI, 2 x USB 2.0 ports, Audio, SPDIF, |
| Internal I/O Port |
2 x COM, 1 x PS2 Key/Mouse, 4 x USB 2.0, 1 x 8-bitGPIO
1 x Audio, 1 x CDIN , LVDS and LCD inverter connector,
1 x 2-pin power connector |
Power Requirement |
DC 12V input |
| Board Dimension |
146mm x 101 mm (L x W) |
Operation Temperature |
0 ~ 60ºC (32 ~ 140ºF) |
