Form Factor |
ATX Motherboard (307 x 244 mm) |
Processor |
Intel® Core™2 Quad / Core™2 Duo Desktop / Pentium D
LGA775 533/800/1066 FSB. |
Memory |
8 x DDR2 533/667/800 MHz support up to 8.0 GB |
Chipset |
Intel® Q965 & ICH8DO Chipset |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min ~ 255 min |
Power Management |
ACPI 1.0 compliant, supports power saving mode ATX PSU |
VGA Interface |
Intel® Q965 integrated GMA 3000 Technology |
Video Memory |
Up to 256 MB shared with system memory |
Serial ATA Interface |
6 x Serial ATA II Interface with 300MB/s transfer rate Support RAID 0,1,5,10 function |
Audio Interface |
Intel® ICH8DO integrated with Realtek ALC888 HD Audio |
LAN Interface |
2 x Intel® 82573L Gigabit Ethernet Controller |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
1 x PCI-Express X16 , 1 x PCI-Express X4 , 4 x PCI slots
1 x Min-PCI , 2 x ISA slots |
External I/O Port |
2 x RJ45 LAN ports, 1x DB15 VGA port, 1 x PS/2 Keyboard / Mouse port , 1x RS232 Serial port , 6 x USB 2.0 ports , 1 x SPDIF , HD Audio ports |
Internal I/O Port |
1 x FDD, 1 x IrDA , 4 x USB 2.0 , 1 x Audio , 1 x LPT
1 x RS232/422/485 & 4 x RS232 |
Power Requirement |
Standard 24-pin ATX power supply ( 20-pin is compatible)
Standard 8-pin 12V power Input connector |
Board Dimension |
307mm x 244 mm (L x W) |
Operation Temperature |
0 ~ 60oC (32 ~ 140oF) |
