Form Factor |
PICMG 1.3 CPU Card |
CPU |
Intel Core 2 Quad /Core 2 Duo / Pentium D / Pentium 4 processor LGA775 @ 533 / 800 / 1066 MHz FSB |
Memory |
2 x DDR2 533/667/800 MHz SDRAM up to 3.0 GB |
Chipset |
Intel Q965 & ICH8DO |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min ~ 255 min |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
VGA Interface |
Intel Q965 integrated GMA (Graphic Media Accelerator) 3000 Technology |
Video Memory |
Up to 256MB shared with system memory |
Serial ATA Interface |
6 x Serial ATA Interface with 300 MB/s transfer rate. support RAID 0/1/5/10 and Intel Matrix Storage Technology |
Audio Interface |
Realtek ALC260 2-channel Audio |
LAN Interface |
2 x Intel 82573L Gigabit Ethernet .( FS-A70G2 Model only) |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
1 x Mini-PCI socket |
External I/O Port |
2x RJ45 LAN port ( FS-A70G2 model ) , 1x DB15 VGA port, 1 x PS/2 Keyboard / Mouse ports, |
| Internal I/O Port |
1 x RS232 & 1 x RS232/422/485, 1 x FDD, 1 x IrDA , 1 x LPT
6 x USB 2.0, 1 x 8-bit GPIO, 1 x Audio, 1 x CDIN , |
Power Requirement |
+5V , +12V input & 5VSB Requirement |
| Board Dimension |
338mm x 122 mm (L x W) |
Operation Temperature |
0 ~ 60 ¡æ |
