免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → OPTIMESS
产品名称: OPTIMESS
型 号:
价 格: 0.00
品 牌: OPTIMESS
OPTImess laser sensors - due to their small size, high measurement frequency, and accuracy as well as their characteristic feature of being capable to operate in nearly all environmental conditions - are developing into a nearly universal measuring device in the areas of research & development, production, quality control and testing.
In geodesy, distance measurements by means of optical triangulation have been used for Ordnance Survey for a long time. On the basis of a known basic length and by defining two angles, it is hereby possible to determine exactly the position of a required point. The OPTImess sensors operate according to the same method.
The laser beam, which is projected by an optical installation, appears on the measuring object''s surface as a diffuse reflecting light spot. This spot is again projected by a second optical installation onto the detector. Each movement of the measuring object in the direction of the beam towards the receptor will result in a movement of the projected spot on the photo detector.
The OPTImess sensors have been developed for the exact measurement of measurable variables as, for example, positions, dimensions, vibrations and thicknesses in the industrial sector.
公司名称: 瑞士ELAG电子有限公司北京代表处
电 话: 010 51285271 / Sandy Zhang
手机:
地 址: 北京朝阳区酒仙桥中路26号丽港2号楼1702室
邮 编: 100016
主 页: http://www.optimess.cn
  • ELAG OPTIMESS®激光三角扫描仪-接触网测量系统
  • 车轮踏面轮廓在线测量系统--OPTIMESS®激光传感器
  • 瑞士OPTIMESS铁路/轮对/接触网/钢轨磨耗测量系统
  • 水平度测量
  • 抗强太阳光干扰-OPTIMESS®公路平整度和纹理测量系统
  • 抗强太阳光干扰--OPTIMESS®公路路面车辙测量系统
  • 偏心率测量
  • OPTIMESS MR CCD
  • 车轮踏面轮廓测量-------OPTIMESS®便携式激光测量仪
  • 轨道叉道段测量
