免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → OPTISCAN
产品名称: OPTISCAN
型 号:
价 格: 0.00
品 牌: OPTIMESS
The dimensional laser scanner OPTIscan, operating in a non-contact process, is a special model of the OPTImess detector. The operating method of the OPTImess sensor is mainly based on the observation of an object at a fixed point; the OPTIscan works according to the same principle, however the measuring point is scanned along a line.
In the OPTIscan, the laser beam is projected, via an optical system, in the shape of a line onto the object. By the use of a second mirror on the same axis the picked-up beam is directed towards the detector.
In this way it is possible to measure exactly the vertical distance along a line. The horizontal position is determined via an angle measuring system at the mirror’s rotation axis.
The use of this type of sensor is advisable for many applications, where a standard OPTImess detector would have to be moved horizontally by a mechanical device. The use of the OPTIscan is possible for applications, which have a relatively narrow scanning width (100mm). This provides a possibility for cost reduction by eliminating the necessity for an elaborate mechanical system.
公司名称: 瑞士ELAG电子有限公司北京代表处
电 话: 010 51285271 / Sandy Zhang
手机:
地 址: 北京朝阳区酒仙桥中路26号丽港2号楼1702室
邮 编: 100016
主 页: http://www.optimess.cn
  • ELAG OPTIMESS®激光三角扫描仪-接触网测量系统
  • 车轮踏面轮廓在线测量系统--OPTIMESS®激光传感器
  • 瑞士OPTIMESS铁路/轮对/接触网/钢轨磨耗测量系统
  • 水平度测量
  • 抗强太阳光干扰-OPTIMESS®公路平整度和纹理测量系统
  • 抗强太阳光干扰--OPTIMESS®公路路面车辙测量系统
  • 偏心率测量
  • OPTIMESS MR CCD
  • 车轮踏面轮廓测量-------OPTIMESS®便携式激光测量仪
  • 轨道叉道段测量
