免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → OPTILINE
产品名称: OPTILINE
型 号:
价 格: 0.00
品 牌: OPTIMESS
OPTIline is a laser-measuring system featuring a separate transmitter (laser) and receiver (detector). By means of the laser and its optical equipment, a line of parallel light is created in the required length, which is being displayed on the detector. If a measuring object between laser and detector interrupts the line, part of the detector is in its shade. The bright/dark transition is very clearly determined on the photo detector (shadow measuring method).
The OPTIline systems provide simple and exact measuring or detection of:
  • diameters
  • widths
  • edges/rims
  • roundness and vertical impact
  • oscillations
公司名称: 瑞士ELAG电子有限公司北京代表处
电 话: 010 51285271 / Sandy Zhang
手机:
地 址: 北京朝阳区酒仙桥中路26号丽港2号楼1702室
邮 编: 100016
主 页: http://www.optimess.cn
  • ELAG OPTIMESS®激光三角扫描仪-接触网测量系统
  • 车轮踏面轮廓在线测量系统--OPTIMESS®激光传感器
  • 瑞士OPTIMESS铁路/轮对/接触网/钢轨磨耗测量系统
  • 水平度测量
  • 抗强太阳光干扰-OPTIMESS®公路平整度和纹理测量系统
  • 抗强太阳光干扰--OPTIMESS®公路路面车辙测量系统
  • 偏心率测量
  • OPTIMESS MR CCD
  • 车轮踏面轮廓测量-------OPTIMESS®便携式激光测量仪
  • 轨道叉道段测量
