免费注册 登录 | 广告服务 | 客服中心
中华工控网 → 工控产品 → OPTICONTROL
产品名称: OPTICONTROL
型 号:
价 格: 0.00
品 牌: OPTIMESS
The data processing unit OPTIcontrol.LC facilitates the digital processing of measuring values. The core of this unit is an 8-bit micro processor Hitachi H8-330.
The standard software of the basic version is designed for general applications (distance measuring, thickness measuring, tolerances monitoring, etc.) and can only be slightly modified for specific measuring tasks. For applications, which necessitate specific data processing, the digital data processing unit OPTIcontrol.16 should be used. This unit (software and hardware) can easily perform special tasks and can be adjusted to specific requirements.
The OPTIcontrol.LC system processes the measuring values of one or two OPTImess (or OPTIline) transducers. The already linearised, analogue measuring signals of the transducers are A/D transformed and then transmitted to the numeric processor, where the measuring data processing is carried out and the in-/output unit is operated.
The in-/output units consist of:
-basic keyboard
-LED-display unit
-output module with:
    -analogue exit
    -serial RS232 interface
    -4-channel digital exit
An additional incremental-module can optionally be provided.
公司名称: 瑞士ELAG电子有限公司北京代表处
电 话: 010 51285271 / Sandy Zhang
手机:
地 址: 北京朝阳区酒仙桥中路26号丽港2号楼1702室
邮 编: 100016
主 页: http://www.optimess.cn
  • ELAG OPTIMESS®激光三角扫描仪-接触网测量系统
  • 车轮踏面轮廓在线测量系统--OPTIMESS®激光传感器
  • 瑞士OPTIMESS铁路/轮对/接触网/钢轨磨耗测量系统
  • 水平度测量
  • 抗强太阳光干扰-OPTIMESS®公路平整度和纹理测量系统
  • 抗强太阳光干扰--OPTIMESS®公路路面车辙测量系统
  • 偏心率测量
  • OPTIMESS MR CCD
  • 车轮踏面轮廓测量-------OPTIMESS®便携式激光测量仪
  • 轨道叉道段测量
