²úÆ·Ãû³Æ£º FS-97C
ÐÍ ºÅ£º FS-97C
Æ· ÅÆ£º ̨Íå¿Ïí®(COMMELL)
Form Factor
PICMG 1.0 CPU Card
CPU
Intel CoreTM Duo / Core 2 Duo processor ( Merom ) processor @ 533 / 667 MHz FSB
Memory
2 x DDR2 533/667 MHz SDRAM up to 3.0 GB
Chipset
Intel 945GME & ICH7M
Real Time Clock
Chipset integrated RTC with onboard lithium battery
Watchdog Timer
Generates a system reset  internal timer for 1min ~ 255 min
Power Management
ACPI 1.0 compliant, supports power saving mode
PCI Enhanced IDE
1 x Ultra ATA/100 IDE channel  up to 2 ATAPI devices
VGA Interface
Intel 945GM integrated GMA (Graphic Media Accelerator) 950 Technology
Video Memory
Up to 224MB shared with system memory
Serial ATA Interface
2 x Serial ATA Interface  with 150 MB/s transfer rate.
Audio Interface
Realtek ALC655  5.1 channel Audio
LAN Interface
2 x Intel 82573L Gigabit Ethernet .( FS-97CDG2 Model only)
Solid State Disk
IDE supports 40-pin DiskOnModule .
CompactFlash Type-II on the rear .
GPIO Interface
Onboard programmable 8-bit digital I/O interface
Extend Interface
2 x Min-PCI socket
External I/O Port
2x RJ45 LAN port, 1x DB15 VGA port, 1 x  PS/2 Keyboard / Mouse ports,
    Internal I/O Port
    1 x RS232 & 1 x RS232/422/485, 1 x FDD, 1 x IrDA , 1 x LPT
    4 x USB 2.0, 1 x 8-bit GPIO, 1 x Audio, 1 x CDIN , 1x DVI
    LVDS and LCD inverter connector .
Power Requirement
+5V , +12V input & 5VSB Requirement
    Board Dimension     338mm x 122 mm (L x W)
Operation Temperature
 0 ~ 60 ¡æ
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
