Form Factor |
Full-size PICMG CPU Card |
CPU |
Intel® Pentium 4 LGA775 with 800 MHz FSB |
Memory |
4 x DDR2 533/400 MHz SDRAM t up to 4 GB |
Chipset |
Intel 915GV and ICH6R |
Real Time Clock |
Intel ICH6R built-in RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset with 1 to 255 sec. / min. |
PCI Enhanced IDE |
One Ultra ATA/100 IDEchannel up to 2 ATAPI devices |
VGA Interface |
Intel 915GV integrated GMA 900 ( Graphics Media Accelerator ) Technology 1 x DB15 and 1 x 16-pin header for analog display devices 1x 26-pin header with DVI interface for digital display devices Dual display Clone/Extended supported |
Video Memory |
Up to 224MB shared with system memory |
Serial ATA Interface |
4 x Serial ATA Interface with 150MB/s transfer rate |
Audio Interface |
Intel ICH6R integrated with Realtek ALC201A AC97 Codec |
LAN Interface |
1 x Intel® 82562EZ PHY 10/100 Mbps LAN Or 3 x Marvell E8053 PCIE Gigbit LAN Onboard additional LAN LED connector |
Solid State Disk |
IDE 1 supports Disk OnModule with +5V power supply
1 x Compact Flash Socket on solder side |
GPIO Interface |
Onboard programmable 8-bit Digital I/O interface |
Internal I/O Port |
1 x FDD, 4 x USB ports,1 x IrDA, 1 x RS232 /422/485 serial port, 1 x VGA port , 1 x Audio port and 1 x CD-in port, 1 x parallel port |
External I/O Port |
1 x RJ45 LAN port, 1x PS/2 keyboard / Mouse ports 1X DB15 VGA port, 1 x DB9 RS232 serial port |
Power Requirement |
ATX Power supply with 24-pin power connector |
| Board Dimension |
338 x 122 mm (L x W) |
Operation Temperature |
0 ~ 60oC (32 ~ 140oF) |
