²úÆ·Ãû³Æ£º FS-97A
ÐÍ ºÅ£º FS-97A
Form Factor
Full-size PICMG-bus CPU Card / Slot PC, Supports PICMG version 1.0   (Rev.  2.0) PCI version 2.0mpliant. ISA 64Ma high drive capacity with TI 245 buffer
CPU
Supports Intel Pentium M & Celeron M processors with FC-PGA 478-pin ( Intel Celeron M 4xx series can''t support )
Memory
2 x 184 pin DDR DIMMs to support up to 2.0GB DDR266/333 SDRAM  Supports unbuffered ECC memory.
Chipset
Intel 82855GME & ICH4
Watchdog Timer
256-level generates system reset programmable watchdog timer
Real Time Clock
Intel ICH4 integrated RTC with onboard lithium battery
Power Management
ACPI 1.0 compliant, supports power saving mode with ATX PSU, RTC alarm,  Software shutdown, Wake on LAN
PCI Enhanced IDE
Supports two IDE channels & up to four IDE drivers,   Supports ¡°Ultra DMA 33/66/100¡±
VGA Interface
Intel 855GME GMCH built-in 256bit 2D/3D VGA controller,   Dynamic vedio memory up to 64MB, Supports one external D-sub 15-pin connector & one internal 2x8-pin header
LVDS Supports up to 24-bit Dual LVDS TFT LCD panel  Inverter connector on board
LAN Interface
On board Intel 82562ET to support 10/100 Ethernet LAN,   Optional Intel 82541PI 100/1000 Mbps on LAN2
Audio Interface
Intel ICH4 built-in AC97 3D audio controller with ALC201A, with CD in, Line in, Mic. In, Speaker out
Multi-I/O Port
1 Floppy connector, 1 Printer port, 2 RS232 port, 1 SIR connector, 4 USB 2.0
1 Y-type cable to support PS2 Keyboard & PS2 mouse, 1 AT keyboard
connector
Mini AGP port
Provide the capable of driving an ADD card to support DVI, TV-out devices  Provide the capable of drive an Mini-AGP card to support AGP 8X/4X graphic  card
Solid State Disk
Onboard Compact Flash Type-II socket
Environment
+5V & +12V DC input from PICMG backplane ne AT 4-pin power connector,  Additional +12V on 4-pin connector for  Pentium 4 PSU Board Dimension: 338 x 122 mm (L x W) Operation Temperature: 0 ~ 60oC (32 ~ 140oF)
FS-97AVL
Full-size PICMG Pentium M DDR CPU Card with 400 FSB,          IntelExtreme Graphics 2, Intel 10/100Mbps LAN, Audio, USB 2.0, Mini-AGP andCompactFlash Interface and ISA 64mA High Drive Capacity
FS-97AVL2
Same as FS-97AVL but with secondary Giga LAN
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
