Form Factor |
Full-size PICMG-bus CPU Card / Slot PC, Supports PICMG version 1.0 (Rev. 2.0) PCI version 2.0mpliant. ISA 64Ma high drive capacity with TI 245 buffer |
CPU |
Supports Intel Pentium M & Celeron M processors with FC-PGA 478-pin ( Intel Celeron M 4xx series can''t support ) |
Memory |
2 x 184 pin DDR DIMMs to support up to 2.0GB DDR266/333 SDRAM Supports unbuffered ECC memory. |
Chipset |
Intel 82855GME & ICH4 |
Watchdog Timer |
256-level generates system reset programmable watchdog timer |
Real Time Clock |
Intel ICH4 integrated RTC with onboard lithium battery |
Power Management |
ACPI 1.0 compliant, supports power saving mode with ATX PSU, RTC alarm, Software shutdown, Wake on LAN |
PCI Enhanced IDE |
Supports two IDE channels & up to four IDE drivers, Supports ¡°Ultra DMA 33/66/100¡± |
VGA Interface |
Intel 855GME GMCH built-in 256bit 2D/3D VGA controller, Dynamic vedio memory up to 64MB, Supports one external D-sub 15-pin connector & one internal 2x8-pin header |
| LVDS |
Supports up to 24-bit Dual LVDS TFT LCD panel Inverter connector on board |
LAN Interface |
On board Intel 82562ET to support 10/100 Ethernet LAN, Optional Intel 82541PI 100/1000 Mbps on LAN2 |
Audio Interface |
Intel ICH4 built-in AC97 3D audio controller with ALC201A, with CD in, Line in, Mic. In, Speaker out |
Multi-I/O Port |
1 Floppy connector, 1 Printer port, 2 RS232 port, 1 SIR connector, 4 USB 2.0
1 Y-type cable to support PS2 Keyboard & PS2 mouse, 1 AT keyboard
connector |
Mini AGP port |
Provide the capable of driving an ADD card to support DVI, TV-out devices Provide the capable of drive an Mini-AGP card to support AGP 8X/4X graphic card |
Solid State Disk |
Onboard Compact Flash Type-II socket |
Environment |
+5V & +12V DC input from PICMG backplane ne AT 4-pin power connector, Additional +12V on 4-pin connector for Pentium 4 PSU Board Dimension: 338 x 122 mm (L x W) Operation Temperature: 0 ~ 60oC (32 ~ 140oF) |
