Form Factor |
Full-size PICMG-bus CPU Card / Slot PC, Supports PICMG version 1.0 (Rev. 2.0) PCI version 2.0 compliant, Support ISA 64mA high drive capacity with TI 245 buffer |
CPU |
Supports Intel Pentium 4 Northwood/Prescott CPU with 400/533/800Mhz FSB frequency, Support Intel Hyper-Threading Technology |
Memory |
2x184 pin DDR DIMMs to support up to 2.0GB DDR SDRAM Supports bandwidth up to 3.2GB/s(DDR400) for Single Channel mode
and 6.4GB/s (DDR400) in Dual Channel mode. Supports non ECC DIMMs |
Chipset |
Intel 82865G & 82801EB |
Watchdog Timer |
256-level generates NMI or system reset programmable watchdog timer |
Real Time Clock |
Intel ICH5 integrated RTC with onboard lithium battery |
Power Manegement |
ACPI 1.0 compliant, supports power saving mode with ATX PSU |
Serial ATA |
Supports two Serial ATA connectors, data transfer rates up to 150MB/s |
PCI Enhanced IDE |
Supports two IDE channels & up to four IDE drivers, Supports ¡°Ultra DMA 33/66/100¡± |
VGA Interface |
Intel 82865G GMCH built-in 256bit 2D/3D VGA controller, Dynamic vedio memory up to 64MB, Supports one external D-sub 15-pin connector & one internal 15-pin header |
LAN Interface |
On board Intel 82547EI to support Gigabit Ethernet LAN, Optional Intel 82562ET 10/100Mb LAN |
Audio Interface |
Intel ICH5 built-in AC97 3D audio controller with ALC201A, with CD in, Line in, Mic. In,Speaker out |
SCSI Interface |
On Board LSI53C1030 to support Dual Channel Ultra-320 SCSI The first Channel is supported with one 68-pin wide SCSI connector. The Second channel is supported with one 68-pin & one 50-pin SCSI connectors |
| Multi-I/O Port |
1 Floppy connector, 1 Printer port, 2 RS232 port, 1 SIR connector, 4 USB 2.0
1 Y-type cable to support PS2 Keyboard & PS2 mouse, 1 AT keyboard
connector |
Mini AGP port |
Provide the capable of driving an ADD card to support LVDS/TMDS/TV/HDTV
devices.Provide the capable of drive an Mini-AGP card to support AGP 8X/4X graphiccard |
Solid State Disk |
Onboard Compact Flash Type-II socket |
Environment |
+5V & +12V DC input from PICMG backplane
One AT 4-pin power connector, Additional +12V on 4-pin connector
for Pentium 4 PSU
Board Dimension: 338 x 122 mm (L x W)
Operation Temperature: 0 ~ 60oC (32 ~ 140oF) |
