²úÆ·Ãû³Æ£º FS-961
ÐÍ ºÅ£º FS-961
Æ· ÅÆ£º ̨Íå¿Ïí®(COMMELL)
  • Form Factor: full-size PICMG (PCI/ISA)-bus CPU card with 32-bit PCI ands 8/16-bit ISA bus interfaces
  • Socket 370 supports FC-PGA Intel® Pentium®-III, FC-PGA/PPGA CeleronTM, VIA C3 CPUs up to 1.4GHz @ FSB 66/100/133 MHz. Support Intel Tualatin/Coppermine FC-PGA2/FS-PGA CPU and VIA C3 Samuel I/II.
  • Chipset: VIA/S3 Twister-T PN133T chipset with VIA 8606T and 686B
  • DRAM: 1 GB PC100/133 SDRAM
  • PCI Enhanced IDE: Dual UltraATA/100 bus master IDE channel up to 4 ATAPI device
  • I/O Ports: two RS232  serial port, one SPP/ECP/EPP parallel port, four 1.1USB, FDD, IrDA, PS/2 keyboard and mouse ports
  • VGA Interface: VIA/S3 Twister VT8606T chipset built-in S3 Savage4 SVGA core with 128-bit 3D engine BIOS selectable 8/16/32 MBytes video memory shared with system memory VGA,SVGA,XGA,SXGA,UXGA mode up to 1280 X 1024 of resolution
  • LCD Interface: Support 36-bit TTL/LVDS TFT/DSTN LCD interface with 256 gray shade integrated 2-channel 110 MhHz LVDS interface up to 1280 X 1024 of resolution
  • TV-out interface: VIA/S3 Twister-T  PN133T 8606T chipset built in VGA core with TV-out encoder support AV and S-video TV-out interface
  • LAN Interface: 10/100Mbps Fast Ethernet interface with RJ45 on bracket
  • SSD: Onboard CompactFlash socket support CompactFlash Card(CFC) Flash memory capacity up to 1 Gbytes, driver free and bootable Jumper selectable master/slave mode on primary IDE port
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
