²úÆ·Ãû³Æ£º HS-770
ÐÍ ºÅ£º HS-770
Æ· ÅÆ£º ̨Íå¿Ïí®(COMMELL)
Form Factor
Hall-size PCI-bus CPU Card
CPU
Support Intel Pentium M /  Celeron M @ 400/533MHz FSB   ( Intel Celeron M 4xx series can''''t support )
Memory
2 x 240 pin DDRII DIMMs to support up to 2.0GB
Chipset
Intel 915GME & ICH6M
Watchdog Timer
256-level generates system reset programmable watchdog timer
Real Time Clock
On chip RTC with battery backup using external li battery
Power Management
ACPI & APM, RTC alarm, Software shutdown, Wake on LAN
PCI Enhanced IDE
Supports one IDE channels & up to two IDE drivers.Supports Ultra DMA 33/66/100
VGA Interface
Intel 915GM GMCH built-in 3D VGA controller, Supports one external DVI connector & one internal 2 x 13-pin header
LVDS
Supports up to 24-bit LVDS . Inverter connector on board
LAN Interface
Dual Gigabit LAN by Marvell E8053
Audio Interface
Intel ICH6M built-in AC97 3D audio controller with ALC201A
Multi-I/O Port
1 Floppy connector, 1 Printer port, 3 RS232 & 1 RS232/422/485 port, 1 SIR connector, 4 USB 2.0 . PS2 Keyboard & PS2 mouse,
Solid State Disk
Onboard Compact Flash Type-II socket
Environment
+5V & +12V DC input from backplane. Operation Temperature: 0 ~ 60oC (32 ~ 140oF)
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
