Form Factor |
Hall-size PCI-bus CPU Card |
CPU |
Fanless onborad VIA Eden 800 MHz CPU @ 133MHz FSB |
Memory |
1 x 184 pin DDR DIMM to support up to 1 GB |
Chipset |
VIA CN400 and VT8237R |
Watchdog Timer |
System reset programmable watchdig timer with 1 ~ 255 of timeout value |
Real Time Clock |
VIA VT8237 built-in RTC with lithium battery |
Power Manegement |
ACPI 1.0 & APM 1.2 compliant, |
PCI Enhanced IDE |
1 x 40-pin & 1 x 44-pin IDE ports interface |
| Serial ATA |
2 x SATA port.Support RAID 0/1 function . |
VGA Interface |
VIA CN400 Built-in S3 Graphic Unichrome Pro IGP graphics core |
| GPIO |
Supports 8 bit digital I/O. |
LVDS optional |
Supports up to 18/24-bit LVDS . Inverter connector on board |
| DVI optional |
Support DVI up to 1600 x 1200 resolution . |
LAN Interface |
Dual LAN. 1 x 10/100Mbps and 1 x Giga Ethernet |
| Expansive Interface |
One Mini-PCI socket for type III . |
Audio Interface |
Built-in AC97 2 channel 3D audio controller with ALC201A |
Multi-I/O Port |
1 Floppy connector, 1 Printer port, 3 RS232 & 1 RS232/422/485 port, 1 SIR connector, 2 USB 2.0 . PS2 Keyboard & PS2 mouse, |
Solid State Disk |
Onboard Compact Flash Type-II socket |
Environment |
Onboard AT 4-pin cinnector DC 5V/12V & 5V standby
.Operation Temperature: 0 ~ 60oC (32 ~ 140oF) |
