Form Factor |
Half-size PISA CPU Card |
CPU |
Intel CoreTM Duo / Core 2 Duo processor ( Merom ) processor @ 533 / 667 MHz FSB |
Memory |
1 x DDR2 533/667 MHz SDRAM up to 2.0 GB |
Chipset |
Intel 945GME & ICH7M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min ~ 255 min |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
PCI Enhanced IDE |
1 x Ultra ATA33 IDE channel up to 2 ATAPI devices |
VGA Interface |
Intel 945GME integrated GMA (Graphic Media Accelerator) 950 Technology |
Video Memory |
Up to 224MB shared with system memory |
Serial ATA Interface |
2 x Serial ATA Interface with 150 MB/s transfer rate. |
Audio Interface |
Realtek ALC655 5.1 channel Audio |
LAN Interface |
2 x Intel 82573L Gigabit Ethernet.( HS-872PDG2 Model only) |
Solid State Disk |
IDE supports 44-pin DiskOnModule .
CompactFlash Type-II on the rear . |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
1 x Mini-PCI socket |
External I/O Port |
2x RJ45 LAN port, 1x DB15 VGA port, 1 x PS/2 Keyboard / Mouse ports, |
| Internal I/O Port |
1 x RS232 & 1 x RS232/422/485, 1 x FDD, 1 x IrDA , 1 x LPT
4 x USB 2.0, 1 x 8-bit GPIO, 1 x Audio, 1 x CDIN , 1x DVI
LVDS and LCD inverter connector . |
Power Requirement |
+5V , +12V input & 5VSB Requirement |
| Board Dimension |
185mm x 127 mm (L x W) |
Operation Temperature |
0 ~ 60 ¡æ |
