Form Factor: half-size ISA-bus CPU card
Socket 370 supports FC-PGA Intel® Pentium®-III, FC-PGA/PPGA CeleronTM, VIA C3 CPUs up to 1.4 GHz @ FSB 66/100/133 MHz.
Support Intel Tualatin/Coppermine FC-PGA2/FS-PGA CPU and VIA C3 Samuel I/II.
Chipset: VIA/S3 Twister-T PN133T chipset with VIA 8606T and 686B
DRAM: 512MBytes 144 Ping SO-DIMM SDRAM
PCI Enhanced IDE: Dual UltraATA/100 bus master IDE channel up to 4 ATAPI device
I/O Ports: two RS232 serial port, one SPP/ECP/EPP parallel port, four 1.1USB, FDD, IrDA, PS/2 keyboard and mouse ports
VGA Interface: VIA/S3 Twister VT8606T chipset built-in S3 Savage4 SVGA core with 128-bit 3D engine BIOS selectable 8/16/32 MBytes video memory shared with system memory VGA,SVGA,XGA,SXGA,UXGA mode up to 1280 X 1024 of resolution
LCD Interface: Support 18-bit TTL/LVDS TFT/DSTN LCD interface with 256 gray shade integrated 2-channel 110 MhHz LVDS interface up to 1280 X 1024 of resolution
LAN Interface: 10/100Mbps Fast Ethernet interface with RJ45 on bracket
SSD: Onboard CompactFlash socket support CompactFlash Card(CFC) Flash memory capacity up to 1 Gbytes, driver free and bootable Jumper selectable master/slave mode on primary IDE port
