Form Factor: hall-size PISA (PCI/ISA)-bus CPU card with 32-bit PCI and 8/16-bit ISA bus interfaces
CPU: onboard embedded VIA Eden 533 MHz CPU at 133 MHz of FSB (Compatible VIA Eden 400/667 and EBGA C3 800 MHz CPU for OEM Project)
Chipset: VIA PLE133T
DRAM: 512 MB PC133 SDRAM on 1 168-pin DIMM socket
PCI Enhanced IDE: dual Channels support 4 ATAPI devices up to UltraATA/100 with 100Mbps of data transfer rate
VGA Interface: VIA 8601T integrated Trident 3D/2D SVGA controller with 8 MB of video memory shared with system
LAN Interface: integrated 10/100 Mbps Fast Ethernet interface
Audio Interface: integrated AC97 3D audio interface
ISA High Drive Capacity: ISA 64mA high drive capacity with TI 74ABT162245 buffer, supports over 20 pieces of ISA-based add-on cards
I/O Ports: one RS232 and one RS232/422/485 serial port, SPP/ECP/EPP parallel port, two USB, FDD, IrDA, PS/2 keyboard and mouse ports
SSD: onboard M-systems DiskOnChip socket up to 576 MBytes of flash disk
