Form Factor: Half-size ISA-bus embedded CPU card / slot PC
CPU: onboard embedded NS Geode GX1 300 MHz CPU
DRAM: Onboard optional 32/64 MB SDRAM and one low profile 144-pin SO-DIMM socket supports additional 256 MB SDRAM. Total memory capacity up to 320 MB.
PCI Enhanced IDE: Dual Channels support 4 ATAPI devices up to UltraDMA/33 with 33 Mbps of data transfer rate. One 40-pin and one 44-pin IDE Port for 2.5" notebook-size HDD, slim CD-ROM/DVD/CD-RW and cable free DOM (DiskOnModule).
VGA Interface: NS Geode CS5530A built-in VGA controller with 2D engine and 4 MB of video memory shared with system.
Flat Panel Interface: Integrated 18-bit LVDS and TTL panel interface for TFT display.
LAN Interface: 10/100BASE-Tx Fast Ethernet interface
Audio Interface: AC97 3D audio interface
Multiple I/O Ports: 2 COM, 1 Parallel and 4 USB ports. Jumper selectable RS-422/485 serial port
SSD: onboard M-systems DiskOnChip solid state disk on 32-pin DIP socket and 40-/44-pin IDE interface for IDE-based M-systems IDE Pro and/or DiskOnModule (DOM) flash disk. The flash memory capacity up to 576 MB on DiskOnChip (DOC) and 512 MB on DiskOnModule (DOM)
Expansible Interface: one 8/16-bit ISA-based PC/104 interface
