²úÆ·Ãû³Æ£º LS-571
ÐÍ ºÅ£º LS-571
Form Factor
5.25" SBC (203 x 146 mm)
CPU
Intel® Core™ 2 Duo (Merom) processor @ 800 MHz FSB
Memory
1 x DDR2 533/667 MHz SODIMM up to 2.0 GB .
Optional onboard 1.0 GB DDRII SDRAM.
Chipset
Intel® GME965 & ICH8M
Real Time Clock
Chipset integrated RTC with onboard lithium battery
Watchdog Timer
Generates a system reset internal timer for 1sec/min ~ 255 sec/min
Power Management
ACPI 1.0 compliant, supports power saving mode
PCI Enhanced IDE
1 x Ultra ATA/33 IDE channel up to 2 ATAPI devices
VGA Interface
Intel® GME965 integrated GMA (Graphic Media Accelerator) X3100 Technology
Video Memory
Up to 384 MB shared with system memory
Serial ATA Interface
3 x Serial ATA II Interface with 300 MB/s transfer rate.
Audio Interface
Realtek ALC888 HD Audio
LAN Interface
2 x Intel® 82573L Gigabit Ethernet
Solid State Disk
IDE1 supports 44-pin DiskOnModule +5V power supply
CompactFlash Type-II on the solder side.
(CompactFlash shared with IDE bus)
GPIO Interface
Onboard programmable 8-bit digital I/O interface
Extend Interface
1 x PCI slot & 2 x Min-PCI socket
DVI Interface
2 x DVI with onboard 26-pin DVI connector (optional)
    LVDS Interface     2 x 18/24-bit Dual-Channel LVDS interface (optional)
    Internal I/O Port
    1 x RS232/422/485, 5 x COM, 1 x silm FDD, 1 x IrDA ,
    1 x LPT, 8 x USB 2.0, 1 x 8-bit GPIO, 1 x Audio, 1 x CDIN
    LVDS and LCD inverter connector, 1 x DVI, 1 x TV-out
    1 x SMBus
Power Requirement
Standard 20-pin ATX power supply or
DC 12V input
    Board Dimension     203 mm x 146 mm (L x W)
Operation Temperature
 0 ~ 60ºC (32 ~ 140ºF)
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
