Form Factor |
5.25 " Embedded Miniboard |
CPU |
Intel CoreTM Duo / Core Solo / Core 2 Duo processor ( Merom ) processor @ 533 / 667 MHz FSB |
Chipset |
Intel 945GME & ICH7M |
Memory |
2 x DDR2 533/667 MHz SDRAM up to 3.0 GB |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min ~ 255 min |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
PCI Enhanced IDE |
One 44-pin Ultra DMA33 IDE interface supports up to 2 ATAPI devices. |
VGA Interface |
Intel 945GME integrated GMA (Graphic Media Accelerator) 950 Technology |
Video Memory |
Up to 224MB shared with system memory |
LVDS interface |
Onboard 18-bit Dual channel LVDS connector . |
Serial ATA interface |
2 x Serial ATA interfaces with 150MB/s transfer rate |
LAN Interface |
4 x Intel 82573L Gigabit Ethernet controller |
Audio |
Intel ICH7-M integrated with Realtek ALC655 5.1 CH AC97 Codec |
GPIO |
Onboard programmable 8-bit Digital I/O interface |
Extend Interface |
1 x PCI slot ,1 x Min-PCI scoket. |
Internal I/O Ports |
1 x PS2, 1 x IrDA, 1 x GPIO, 1 x AUDIO, 1 x CDIN, 1 x LVDS, 4 x USB2.0 , 1 x DVI, 1 x LCD Inverter, 1 x FDD, 1 x LPT,1 x 44-pin IDE, 2 x RS232, 1 x RS232/RS422/485 |
External I/O Ports |
1 x COM, 1 x VGA, 4 x RJ45, 2 x USB2.0, 1 x 2-pin power jack |
Solid State Disk |
Onboard 44-pin IDE support DOM, CF on solder side . |
Power Requirement |
Standard 24-pin ATX power supply (20-pin is compatible) Or 8~24V full range DC Input |
Temperature |
Operating within 0~60 centigrade ,Storage within -20~85 centigrade |
Dimension (L x W ) |
146 x 203 mm |
