| Form Factor |
5.25" Miniboard, 146 x 203 mm or 5.75" x 8.00" |
| CPU |
Onboard embedded VIA V4 Eden 1 GHz CPU |
| Chipset |
VIA CN700 & VT8237R+ |
| Memory |
Onboard optional 256 MB DDR SDRAM and one 184-pin slot supports additional 1GB DDR SDRAM. |
| Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
| Watchdog Timer |
Generate system reset with 1 to 255 Sec./Min of time out value |
| PCI Enhanced IDE |
Dual Channels support 4 ATAPI devices up to UDMA/133. One 40-pin and one 44-pin IDE Port for 2.5" notebook-size HDD, slim CD-ROM/DVD/CD-RW and cable free DOM (DiskOnModule). |
| VGA Interface |
VIA CN700 integrated UniChrome pro 2D/3D Graphics controller and max 64 MB of video memory shared with system memory |
| LVDS interface |
VIA VT1636 LVDS transmitter, 18/24-bit Dual channel LVDS |
| Serial ATA interface |
2 x Serial ATA interfaces , RAID 0 / 1 support |
| LAN Interface |
4 x Realtek RTL8110S-32 Gigabit Ethernet controller |
| Audio |
VIA VT8237R+ integrated with Realtek ALC655 5.1 CH AC97 |
| GPIO |
Onboard programmable 8-bit Digital I/O interface |
| Internal I/O Ports |
1 x PS2, 1 x RS232/422/485, 2 x RS232, 1 x Audio, 1 x LPT, 1 x LVDS, 4 x LAN LED pin-header, 4 x USB, 1 x silm-FDD |
| External I/O Ports |
1 x RS232, 1 x VGA, 4 x RJ45, 2 x USB2.0, 1 x 2-pin power jack |
| Solid State Disk |
Onboard CompactFlash socket support CFC (Compact Flash Card) |
| Expansible Interface |
One PCI expansive slot supports up to 2 PCI add-on cards via an additional riser card and one Mini-PCI socket ( the second PCI Bus master of PCI slot is shared with Mini-PCI ) |
Environment Power |
Requirement: +12V P4 4-pin power connector or
+12V DC jack input connector |
| Operation Temperature |
0 ~ 60 ¡ãC(32 ~ 140¡ãF) |
| Board Dimension (L x W ) |
146 x 203 mm or 8.00 x 5.75. |
