Form Factor: 5.25" Drive Size EBX Miniboard, 146 x 203 mm or 5.75" x 8.00"
CPU: onboard embedded VIA Eden 667/533/400 MHz CPU at 133 MHz of FSB
DRAM: Onboard 128/256 MB PC133 SDRAM and one 168-pin DIMM slot supports additional 512 MB SDRAM. Total memory capacity up to 768 MB.
PCI Enhanced IDE: Dual Channels support 4 ATAPI devices up to UltraATA/100 with 100Mbps of data transfer rate. One 40-pin and one 44-pin IDE Port for 2.5" notebook-size HDD, slim CD-ROM/DVD/CD-RW and cable free DOM (DiskOnModule).
VGA Interface: VIA/S3 Twister PN133T chipset integrated Savage4 SVGA controller with 128-bit 3D/2D engine and 8/16/32 MB of video memory.
Flat Panel Interface: Integrated 36-bit dual channel LVDS/TTL flat panel interface.
LAN Interface: Dual 10/100BASE-Tx Fast Ethernet interface
Audio Interface: AC97 3D audio interface
Multiple I/O Ports: 4 COM, 2 Parallel and 4 USB ports. Jumper selectable RS-422/485 serial port and +5V/+12V power pin
SSD: onboard CompactFlash Type-II socket support CFC (Compact Flash Card) and IBM MicroDrive up to 1 GB of solid state flash disk
Expansible Interface: one 32-bit PCI-based PC/104-plus and 8/16-bit ISA-based PC/104 interface support PC/104-plus / PC/104 embedded peripheral module. One PCI expansive slot supports up to 2 PCI add-on cards via an additional riser card
