Form Factor: 5.25" Drive-size EBX-compliant Miniboard
Socket 370 supports Intel Pentium-III, Celeron and VIA C3 CPU up to 1.4 GHz @ 66/100/133 MHz of FSB. Intel latest Tualatin CPU supported.
DRAM: 512 MBytes PC100/133 SDRAM on one 168-pin DIMM socket
Chipset: VIA/S3 Twister-T chipset with PN133T 8606 and 686B
VGA Interface: VIA/S3 Twister-T PN133T 8606 chipset built-in S3 Savage4 3D SVGA core with 32 MBytes video memory shared with system memory.
LCD Interface: VIA/S3 Twister-T PN133T 8606 chipset built-in dual channel 18-bit LVDS and TTL interface for TFT and DSTN LCD panel.
TV-out Interface: VIA/S3 Twister-T PN133T 8606 chipset built-in VGA core with TV-out encoder, offers AV and S-video interface.
PCI Enhanced IDE: dual Channels support 4 ATAPI devices up to UltraATA/100 with 100 MBytes/sec of data transfer rate. One 40-pin and one 44-pin IDE port. (Compatible with 40/44-pin DiskOnModule embedded flash disk)
LAN Interface: Onboard PCI 10/100 Mbps Fast Ethernet interface
AC97 3D audio with line-in, line-our, CD-in and Mic-in interfaces
I/O Ports: three RS232 and one jumper selectable RS-232/422/485 serial port, two parallel port, two USB, FDD, IrDA, PS/2 keyboard and mouse ports
16-bit GPIO port with 8-bit independent digital input and 8-bit independent digital output
Expansive Interface: One PCI slot up to 3 bus master PCI via riser card. One 8/16-bit ISA-based PC/104 and one 32-bit PCI-based PC/104-plus interface.
Solid State Disk: onboard M-systems DiskOnChip socket up to 576 MB of flash disk
