Form Factor |
3.5" Miniboard (146 x 101 mm) |
CPU |
Intel Core 2 Duo / Core Duo / Core Solo processor @ 533 / 667 MHz FSB |
Memory |
1 x DDR2 SO-DIMM up to 2.0 GB |
Chipset |
Intel 945GME & ICH7M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min ~ 255 min |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
PCI Enhanced IDE |
1 x Ultra ATA/33 IDE channel up to 2 ATAPI devices |
VGA Interface |
Intel 945GM integrated GMA (Graphic Media Accelerator) 950 Technology |
DVI Interface |
Onboard Chrontel CH7307C DVI transmitter for DVI interface |
Video Memory |
Up to 224MB shared with system memory |
Serial ATA Interface |
2 x Serial ATA Interface with 150 MB/s transfer rate. |
Audio Interface |
Realtek ALC655 5.1 channel Audio |
LAN Interface |
1 x Intel 82573L Gigabit Ethernet |
Solid State Disk |
IDE supports 44-pin DiskOnModule +5V power supply
CompactFlash Type-II . |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
1 x Min-PCI scoket |
External I/O Port |
1x RJ45 LAN port, 1x DB15 VGA port, 1 x PS/2 Keyboard / Mouse ports, 2 x USB 2.0 ports, 1 x COM |
| Internal I/O Port |
1 x RS232/422/485, 1 x DVI, 1 x IrDA , 2 x USB 2.0,
1 x 8-bit GPIO, 1 x Audio, 1 x CDIN,
18-bit LVDS and LCD inverter connector |
Power Requirement |
8 ~ 24 V full range DC input . |
| Board Dimension |
146 x 101 mm (L x W) |
Operation Temperature |
0 ~ 60oC (32 ~ 140oF) |
