²úÆ·Ãû³Æ£º LE-370Z
ÐÍ ºÅ£º LE-370Z
Æ· ÅÆ£º ̨Íå¿Ïí®(COMMELL)
  • Form Factor: 3.5" Fanless miniboard
  • CPU: Intel Celeron M 600MHz processor.
  • Memory: Onboard 1 x DDR200/266 SDRAM up to 1 GB
  • Chipset : Intel 82852GM & ICH4
  • Real Time Clock : Chipset Integrated RTC with onboard lithium battery
  • Watchdog Timer : Generates a system reset with internal timer for 1min ~ 255min
  • Power Management : ACPI 1.0 compliant, supports power saving mode with ATX PSU
  • PCI Enhanced IDE: One ATA100 IDE channel supports up to 2 ATAPI devices.Onboard 1 x 44-pin IDE connectors
  • VGA Interface: Intel 852GM built-in Intel Extreme Technology
  • LCD Interface: 24-bit LVDS interface up to 1400 x 1050 of resolution.Onboard 5-pin LCD inverter connector.
  • LAN Interface: 1 x Intel 82562ET 10/100Mbps PHY.
  • Audio Interface: Realtek ALC201A AC97 Codec.
  • Solid State Disk: IDE1 supports DiskOnModule with + 5V power supply.1 x CF socket.
  • Internal I/O Ports: 1x IrDA port, 1x Parallel and 2 x USB ports.1 x Serial Port, 1x silm FDD ,1 x VGA output header.
  • External I/O Ports: 1 x RJ45 LAN ports, 1x DB15 VGA port and 1x PS/2 port, 1x RS232 port, 1 x Phone jack. 1x DC Jack
  • Extended Interface: 1 x  Mini-PCI slot.  Extended PCI interface through optional riser card up to 2 devices.
  • Power Requirement : DC 12V input
  • Board Dimension : 146 mm x 101 mm (L xW)
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
