²úÆ·Ãû³Æ£º LE-365
ÐÍ ºÅ£º LE-365
Æ· ÅÆ£º ̨Íå¿Ïí®(COMMELL)
  • Form Factor: 3.5" Embedded Miniboard
  • CPU: Embedded VIA Eden 1.0 GHz CPU
  • Memory: Onboard 1 x 200-pin SO-DIMM DDRII 400/533 up to 1.0 GB
  • Chipset : VIA CX700M
  • Real Time Clock : Chipset Integrated RTC with onboard lithium battery
  • Watchdog Timer : Generates a system reset with internal timer for 1 ~ 255 min/s
  • Power Management : ACPI 1.0 compliant, supports power saving
  • PCI Enhanced IDE: One ATA133 IDE channel supports up to 2 ATAPI devices. Onboard 1 x 44-pin IDE connectors
  • VGA Interface: VIA CX700M integrates S3 Graphics UniChrome Pro II graphic core.       64 MB of video memory shared with system.
  • LVDS Interface: Optional 18/24-bit LVDS interface.
  • DVI Interface: Optional DVI interface.
  • LAN Interface: 1 x Realtek RT8110S-32 Giga Ethernet controller.
  • Serial ATA interface: 2 x SATA interface up to 300 MB/s transfer rate.
  • Audio Interface: VIA VT1708A HD Audio
  • Solid State Disk: IDE1 supports DiskOnModule with + 5V power supply.1 x CF socket.
  • Internal I/O Ports: 1x IrDA port, 2 x USB ports.1 x Serial Port, 1 x LVDS & CDIN (optional), 1 x  DVI (optional), 1 x 44-pin IDE, 1 x 5V/12V DCout
  • External I/O Ports: 1 x RJ45 LAN ports, 1x DB15 VGA port and 1x PS/2 port, 1x RS232 port, 2 x USB2.0, 1 x DC Jack
  • Extended Interface: 2 x Mini-PCI slot.
  • Power Requirement : Full range DC 8 ~ 24V input
  • Board Dimension : 146 mm x 101 mm (L xW)
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
