Form Factor: 3.5" Fanless Embedded Miniboard .
CPU: Onboard AMD Geode GX533 processor .
Memory: Optional onboard 128MB DDR Memory and 1 x 200-pin DDR SODIMM socket supports up to 512 MB.
Chipset : AMD Geode CS5535 .
Real Time Clock : Chipset Integrated RTC with lithium battery .
Watchdog Timer : System reset programmable watchdog timer with 1 ~ 255 sec./min of timeout value .
Power Managerment : ACPI 1.0 version and APM version 1.2 compliant .
PCI Enhanced IDE: One UDMA33 IDE interface supports up to 2 ATAPI devices. Onboard 1 x 44-pin IDE connector .
VGA Interface: AMD Geode GX533 built-in VGA controller with 2D engine .
LCD Interface: 18/24-bit TTL/LVDS (single channel) Interface .
LAN Interface: 2 x Realtek RTL8100B Controller.
Audio Interface: Realtek ALC201A AC97 Codec.
Multi-I/O Ports: 2 x RJ45 LAN ports, 1 x DB15 VGA port and 1 x PS/2 port, 2 x RS232 port,2 x USB 1.1 ports, 1 x LPT, 1 x IrDA, 1 x FDD, 1 x DC Jack .
External Audio Port: Line -out , Line-in and MIC-in .
Solid States Disk : Compact Flash connector Type I .
Extended Interface: 1 x Mini-PCI & PCMCIA slot interface .
Power Requirement : DC 12V input .1 x DC jack or onboard 4-pin 12V DC connector .
Board Dimmension : 146 mm x 101 mm (L xW)
