Form Factor: 3.5" drive size with 146 x 101 mm (3.5" HDD size)
CPU: onboard embedded VIA Eden 667 MHz CPU
Memory: Onboard one 144-pin SO-DIMM socket supports additional 512 MB SDRAM. Onboard optional 128MB PC133 SDRAM
PCI Enhanced IDE: Two IDE channel supports up to 4 ATAPI devices. One 44-pin IDE Port for 2.5" notebook-size HDD, slim CD/DVD-ROM/RW. One 40-pin IDE Port for 3.5" HDD. CD/DVD-ROM/RW.
VGA Interface: Built-in VGA controller with 3D engine and 8/16/32/64 MB of fram buffer shared with system memory. Integrated MPEG-I/II decoder support CRT SVGA/TV-out for both NTSC and PAL system.
Flat Panel Interface: Integrated TTL interface for TFT display.
LAN Interface: 10/100BASE-Tx Fast Ethernet interface, Support Wake-On-LAN function.
Audio Interface: AC97 3D audio interface
Multiple I/O Ports: 1 COM, 1 Parallel and 2 USB 2.0, 1 FPC connector for slim floppy, 1 IrDA, 1 fro PS/2 keyboard and mouse ports.
SSD: onboard CompactFlash socket supports CFC (Compact Flash Card) and IBM MicroDrive up to 1 GBytes of flash memory capacity.
Expansible Interface: one 32-bit ISA-based PC/104-plus interface
Power Requirement: Dual voltage +5V, +12V operation.
