²úÆ·Ãû³Æ£º LE-564
ÐÍ ºÅ£º LE-564
Form Factor 5.25" Drive Size EBX Miniboard, 146 x 203 mm or 5.75" x 8.00"
CPU
Onboard embedded VIA Eden 533 MHz CPU @ 133 MHz FSB
DRAM
Onboard 128/256 MB PC133 SDRAM and one 168-pin DIMM slot supports additional 512 MB SDRAM. Total memory capacity up to 640 MB
Universal Console Redirectly (UCR) Option installable feature for monitoring POST messages and running Setup and Operating system from a Serial terminal
PCI Enhanced IDE
Dual Channels support 4 ATAPI devices up to UltraATA/100 with 100Mbps of data transfer rate. One 40-pin and one 44-pin IDE Port for 2.5" notebook-size HDD, slim CD-ROM/DVD/CD-RW and cable free DOM (DiskOnModule).
VGA Interface
VIA Apollo PLE133 chipset integrated  with VT8601 via UMA Architecture and max 8 MB of video memory shared with system memory
LAN Interface
4 x Realtek 8139C+ 10/100BASE-Tx Fast Ethernet
or 3 x Intel 82551QM 10/100BASE-Tx with 1 x Intel 82540EM  10/100/1000BASE-T Giga Ethernet interface
Multiple I/O Ports
2 COM, 1 Parallel, 2 USB ports.
Solid State Disk
Onboard CompactFlash Type-I/II socket support CFC (Compact Flash Card)  up to 1 GB of solid state flash disk
Expansible Interface
One PCI expansive slot supports up to 2 PCI add-on cards via an additional riser card and one Mini-PCI socket optional use with PCI slot
Environment Power
Requirement: +5V with onboard AT/4P power connector or
+5V AC/DC jack input connector
Board Dimension (L x W ) 146 x 203 mm or 8.00 x 5.75? Operation Temperature: 0 ~ 60oC (32 ~ 140oF)
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
