| Form Factor |
5.25" Drive Size EBX Miniboard, 146 x 203 mm or 5.75" x 8.00" |
| CPU |
Onboard embedded VIA Eden 533 MHz CPU @ 133 MHz FSB |
| DRAM |
Onboard 128/256 MB PC133 SDRAM and one 168-pin DIMM slot supports additional 512 MB SDRAM. Total memory capacity up to 640 MB |
| Universal Console Redirectly (UCR) |
Option installable feature for monitoring POST messages and running Setup and Operating system from a Serial terminal |
| PCI Enhanced IDE |
Dual Channels support 4 ATAPI devices up to UltraATA/100 with 100Mbps of data transfer rate. One 40-pin and one 44-pin IDE Port for 2.5" notebook-size HDD, slim CD-ROM/DVD/CD-RW and cable free DOM (DiskOnModule). |
| VGA Interface |
VIA Apollo PLE133 chipset integrated with VT8601 via UMA Architecture and max 8 MB of video memory shared with system memory |
| LAN Interface |
4 x Realtek 8139C+ 10/100BASE-Tx Fast Ethernet
or 3 x Intel 82551QM 10/100BASE-Tx with 1 x Intel 82540EM 10/100/1000BASE-T Giga Ethernet interface |
| Multiple I/O Ports |
2 COM, 1 Parallel, 2 USB ports. |
| Solid State Disk |
Onboard CompactFlash Type-I/II socket support CFC (Compact Flash Card) up to 1 GB of solid state flash disk |
| Expansible Interface |
One PCI expansive slot supports up to 2 PCI add-on cards via an additional riser card and one Mini-PCI socket optional use with PCI slot |
Environment Power |
Requirement: +5V with onboard AT/4P power connector or
+5V AC/DC jack input connector |
| Board Dimension (L x W ) |
146 x 203 mm or 8.00 x 5.75? Operation Temperature: 0 ~ 60oC (32 ~ 140oF) |
