Form Factor |
Mini-ITXexpress Motherboard (170 x 170 mm) |
CPU |
Intel CoreTM Duo / Core 2 Duo processor ( Merom ) processor @ 533 / 667 MHz FSB |
Memory |
2 x DDR2 533/667 MHz SDRAM up to 3.0 GB |
Chipset |
Intel 945GME & ICH7M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min ~ 255 min |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
PCI Enhanced IDE |
1 x Ultra ATA/33 IDE channel up to 2 ATAPI devices |
VGA Interface |
Intel 945GM integrated GMA(Graphic Media Accelerator) 950 Technology |
Video Memory |
Up to 224MB shared with system memory |
Serial ATA Interface |
2 x Serial ATA Interface with 150 MB/s transfer rate. |
Audio Interface |
Realtek ALC880 5.1 channel Audio |
LAN Interface |
1 x Intel 82573L Gigabit Ethernet |
Solid State Disk |
IDE1 supports 44-pin DiskOnModule +5V power supply
CompactFlash Type-II on the rear . |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
1 x Onboard x16 PCI-Express slot ( x1 mode compatible)
2 x Min-PCI scoket |
External I/O Port |
1x RJ45 LAN port, 1x DB15 VGA port, 1 x PS/2 Keyboard / Mouse ports, 1 x IEEE 1394 ports, 2 x USB 2.0 ports, Audio, SPDIF , DC input connector ( LV-677DC version only) |
| Internal I/O Port |
1 x RS232 & 1 x RS232/422/485, 1 x silm FDD, 1 x IrDA ,
4 x USB 2.0, 1 x 8-bit GPIO, 1 x Audio, 1 x CDIN
LVDS and LCD inverter connector |
Power Requirement |
Standard 24-pin BTX power supply for LV-677 .
( 20-pin ATX is compatible)
8 V ~ 21 V full range DC input for LV-677DC . |
| Board Dimension |
170mm x 170 mm (L x W) |
Operation Temperature |
0 ~ 60oC (32 ~ 140oF) |
