²úÆ·Ãû³Æ£º LV-675
ÐÍ ºÅ£º LV-675
Form Factor
Mini-ITX form factor at 170 x 170 mm
CPU
Micro-FCPGA 478 Mobile Intel® Pentium M / Celeron M CPU
up to 2.26 GHz  @ 400/533 MHz FSB
( Intel® Celeron M 4xx series can''t support )
Memory
One 184-pin DIMM socket
Support up to 1 GBytes DDR 200/266/333 SDRAM
Chipset
 Intel® high performance chipset
Watchdog Timer
Generates a system reset with internal timer for 1 to 255 sec.
Power Management
ACPI 2.0 compliant, supports power saving mode .
Real Time Clock
Intel® ICH4 built-in RTC with onboard lithium battery
PCI Enhanced IDE
40-pin UltraATA/100 bus master IDE channels
And one onboard 44-pin IDE connector
VGA Interface
Built-in Intel® Extreme Graphics
Video Memory up to 64 MB shared with system
   External DB15 female connector on rear I/O panel
LVDS /DVI Interface
Optional Dual channel 18/24-bit LVDS or DVI interface
TV-out Interface
S-video & Composite TV-out
LAN Interface
Intel® 82541PI Giga Mbps Ethernet interface
Audio Interface
Onboard ACL655 AC97 3D audio codec
5.1 channel, line-in, line-out, Mic-in, CD-in and S/P DIF interface
Hi-Speed USB 2.0
Intel® ICH4 chipset built-in Hi-Speed USB 2.0 interface
with 480 Mbps of data transfer rate and bootable setting in BIOS
Multi-I/O Port
1 x RS232 & 1 x RS232/422/485, 1 x parallel, 4 x USB 2.0, 1 x IrDA,
1 x FDD, 8-bit GPIO, 1 x PS/2 keyboard and mouse port.
Solid State Disk
IDE support DiskOn Module with +5V power supply
Expansive Slot
One 32-bit PCI slot supports 2 bus master PCI via riser card,
and 2 x Mini-PCI
Environment
   Power Requirement: Standard 20/24-pin ATX power supply
   Dimension (W x L): 170mm x 170mm with standard Mini-ITX form factor
   Operation Temperature: 0 ~ 60oC (32 ~ 140oF)
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
