Form Factor |
Mini-ITXexpress Motherboard (170 x 170 mm) |
CPU |
Intel Pentium D / Celeron D LGA775 533/800/1066 FSB.
Support EM64T , Dual Core ( Don''t support Intel® Pentium® Processor Extreme Edition ) |
Memory |
2 x DDR2 533/667 MHz SDRAM up to 2GB |
Chipset |
Intel 945G & ICH7R |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min ~ 255 min |
Power Management |
ACPI 1.0 compliant, supports power saving mode ATX PSU |
PCI Enhanced IDE |
1 x Ultra ATA/100 IDE channel up to 2 ATAPI devices |
VGA Interface |
Intel 945G integrated GMA (Graphic Media Accelerator) 950 Technology |
Video Memory |
Up to 224MB shared with system memory |
Serial ATA Interface |
4 x Serial ATA II Interface with 300MB/s transfer rate Support RAID 0,1,5,10 function |
Audio Interface |
Intel ICH7R integrated with Realtek ALC882 7.1 CH High Definition Audio |
LAN Interface |
4 x Marvell E8053 Gigabit Ethernet Controller |
Solid State Disk |
IDE1 supports DiskOnModule +5V power supply |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
1 x Onboard 16x PCI-Express slot (x 1 mode compatible)
1 x Min-PCI socket |
External I/O Port |
4 x RJ45 LAN port, 1x DB15 VGA port,1x PS/2 Keyboard / Mouse ports 2 x RS232 Serial port , 1 x IEEE1394 ports, 2 x USB 2.0 ports |
| External Audio Port |
Line-in, Line-out , MIC-in , Front , Rear , Center/Subwoofer
and side outputs. |
| Internal I/O Port |
1 x slim FDD, 1 x IrDA , 2 x USB 2.0 , 1 x IEEE 1394 , 1 x
CDIN , 1 x S/PDIF |
Power Requirement |
Standard 24-pin ATX power supply. ( 20-pin is compatible) |
| Board Dimension |
170mm x 170 mm (L x W) |
Operation Temperature |
0 ~ 60oC (32 ~ 140oF) |
