Form Factor |
Mini-ITXexpress Motherboard |
CPU |
Intel® Pentium® M / Celeron M
Package type: FC-PGA478
Front side bus: 400/533 MHz
( Intel Celeron M 4xx series can''t support ) |
Memory |
2 x DDR2 400/533 MHzSDRAM up to 2GB |
Chipset |
Intel 915GME & ICH6M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min ~ 255 min |
Power Management |
ACPI 1.0 compliant, supports power saving mode with DC adapter |
PCI Enhanced IDE |
1 x Ultra ATA100 IDE channel up to 2 ATAPI devices |
VGA Interface |
Intel 915G integrated GMA(Graphic Media Accelerator) 900 Technology. |
Video Memory |
Up to 128MB shared with system memory |
Serial ATA Interface |
2 x Serial ATA Interface with 150MB/s transfer rate |
Audio Interface |
Intel ICH6M integrated with Realtek ALC880 HD Audio |
LAN Interface |
2 x Marvell 8053 PICE Gigabit LAN . |
Solid State Disk |
IDE1 supports DiskOnModule +5V power supply
1 x CompactFlash socket on solder side. |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
1 x Onboard 16x PCI-Express slot (1 x mode compatible)
1 x Min-PCI socket
1 x PCMCIA Type II slot on solder side |
External I/O Port |
2 x RJ45 LAN port, 1 x DB15 VGA port, 1 x PS/2 Keyboard / Mouse ports, 2 x RS232 Serial port , 1 x DC Mini-DIN, 4 x USB 2.0 ports |
| External Audio Port |
Line-in , Front, MIN-in , Surround , Center , BackSurround |
Power Requirement |
DC 12V |
| Board Dimension |
170mm x 170 mm (L x W) |
Operation Temperature |
0 ~ 60oC (32 ~ 140oF) |
