Form Factor |
Mini-ITX compact motherboard |
CPU |
Intel® Pentium® 4 LGA775 533/800 MHz FSB |
Memory |
2 x DDR2 400/533 MHz SDRAM up to 2GB |
Chipset |
Intel 915G & ICH6R |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min ~ 255 min |
Power Management |
ACPI 1.0 compliant, supports power saving mode ATX PSU |
PCI Enhanced IDE |
1 x Ultra ATA/100 IDE channel up to 2 ATAPI devices |
VGA Interface |
Intel 915G integrated GMA(Graphic Media Accelerator) 900 Technology , support Dual Display , optional DVI or LVDS Module |
Video Memory |
Up to 224MB shared with system memory |
Serial ATA Interface |
4 x Serial ATA Interface with 150MB/s transfer rate |
Audio Interface |
Intel ICH6R integrated with Realtek ALC655 5.1 CH AC97 Codec |
LAN Interface |
2 x Intel 82541GI Gigabit Ethernet Controller . |
Solid State Disk |
IDE1 supports DiskOnModule +5V power supply |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
1 x Onboard 16X PCI-Express slot (1 x mode compatible)
1 x Min-PCI scoket on solder side |
External I/O Port |
2 x RJ45 LAN port, 1x DB15 VGA port,1x PS/2 Keyboard / Mouse ports 2 x RS232 Serial port , 2 x IEEE1394 ports, 4 x USB 2.0 ports |
| External Audio Port |
Line-out/Front, Line-in/Rear and MIC-in/Center |
Power Requirement |
Standard BTX power supply |
| Board Dimension |
170mm x 170 mm (L x W) |
Operation Temperature |
0 ~ 60oC (32 ~ 140oF) |
