Form Factor: Mini-ITX @ 170 x 170 mm
Socket 478 supports Intel mPGA478 Pentium 4 / Celeron CPU @ 533/400 MHz FSB
Chipset: Intel 845GV GMCH and 82801DB ICH4
DRAM: 1 GB DDR266/333 SDRAM
PCI Enhanced IDE: dual Channels support 4 ATAPI devices up to UltraATA/ 100 with 100Mbps of data transfer rate. One 40-pin and one 44-pin IDE port for both of desktop and slim type ATAPI devices.
VGA Interface: Intel 845GV GMCH built-in Intel Extreme Graphics with 266 MHz VGA core, 256-bit 3D engine and dynamic video memory
LAN Interface: Intel PRO/100+ 10/100 Mbps Fast Ethernet interface
Hi-Speed USB 2.0 interface with up to 480 Mbps of data transfer rate
IEEE 1394 interface with 100/200/400 Mbps of data transfer rate
TV-out interface with AV and S-video output
AC97 3D 5.1-CH / SPDIF audio interface
I/O Ports: One serial port, parallel port, FDD, IrDA, PS/2 keyboard and mouse port
SSD: IDE-based DiskOnModule with up to 256 MBytes of flash memory capacity
Expansive Interface: one PCI slot up to 2 bus master PCI expansive slots via riser card
Pentium 4 additional +12V power free for standard ATX power supply
