²úÆ·Ãû³Æ£º LV-670
ÐÍ ºÅ£º LV-670
Æ· ÅÆ£º ̨Íå¿Ïí®(COMMELL)
  • Form Factor: Mini-ITX @ 170 x 170 mm
  • Socket 478 supports Intel mPGA478 Pentium 4 / Celeron CPU @ 533/400 MHz FSB
  • Chipset: Intel 845G series (GV/GE) GMCH and 82801DB ICH4
  • DRAM: 1 GB DDR200/266 SDRAM (LV-670) or DDR266/333 SDRAM (LV-670GE)
  • PCI Enhanced IDE: dual Channels support 4 ATAPI devices up to UltraATA/100 with 100Mbps of data transfer rate. One 40-pin and one 44-pin IDE port for both of desktop and slim type ATAPI devices.
  • VGA Interface: Intel 845G (GV/GE) GMCH built-in Intel Extreme Graphics with 266 MHz VGA core, 256-bit 3D engine and dynamic video memory
  • LAN Interface: Intel PRO/100+ 10/100 Mbps Fast Ethernet interface
  • Hi-Speed USB 2.0 interface with up to 480 Mbps of data transfer rate
  • IEEE 1394 interface with 100/200/400 Mbps of data transfer rate
  • TV-out interface with AV and S-video output
  • AC97 3D 5.1-CH / SPDIF audio interface
  • I/O Ports: One serial port, parallel port, FDD, IrDA, PS/2 keyboard and mouse port
  • SSD: IDE-based DiskOnModule with up to 256 MBytes of flash memory capacity
  • Expansive Interface: one PCI slot up to 2 bus master PCI expansive slots via riser card
  • Pentium 4 additional +12V power free for standard ATX power supp
    ¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
    µç »°£º 021 51086209 / Íõ¼á
    ÊÖ»ú£º 13916842198
    µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
    ÓÊ ±à£º 200438
    Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
