Form Factor |
Mini-ITX Motherboard (170 x 170 mm) |
CPU |
Onboard VIA C7 1.5 GHz processor. |
Memory |
1 x 184-pin DDR up to 1 GB and optional onboard 256 MB SDRAM |
Chipset |
VIA CN700 & VT8237R+ |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1min ~ 255 min |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
PCI Enhanced IDE |
2 x DMA133 IDE channel up to 4 ATAPI devices. (1 x 40-pin and 1 x 44-pin) |
VGA Interface |
VIA CN700 integrated Unichrome Pro 3D/2D Graphics controller. |
Serial ATA Interface |
2 x Serial ATA Interface with 150 MB/s transfer rate. |
Audio Interface |
Realtek ALC655 5.1 channel Audio |
LAN Interface |
2 x Realtek RTL8110S-32 Gigabit Ethernet . |
Solid State Disk |
IDE1 supports 44-pin DiskOnModule +5V power supply
CompactFlash Type-II on the rear . |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
1 x PCI slot , 1 x Min-PCI socket |
External I/O Port |
2 x RJ45 LAN port, 1x DB15 VGA port, 1 x PS/2 Keyboard / Mouse ports, 2 x COM, 1 x IEEE 1394 ports, 4 x USB 2.0 ports, Audio , DC input connector |
| Internal I/O Port |
1 x RS232 & 1 x RS232/422/485, 1 x slim FDD, 1 x IrDA ,
2 x USB 2.0, 1 x 8-bit GPIO, 1 x Audio, 1 x LPT |
Power Requirement |
8 V ~ 24 V full range DC input , onboard 4-pin 12V connector |
| Board Dimension |
170mm x 170 mm (L x W) |
Operation Temperature |
0 ~ 60oC (32 ~ 140oF) |
