Form Factor: 17 x 17 cm Mini-ITX
CPU: support AMD Geode NX Processor .
Chipset: VIA KN400A & VT8237R
Memory: One 184-pin DIMM socket supports up to 2GB
VGA Interface: built-in S3 UniChrome 3D/2D graphics core
Enhanced IDE: One UltraATA/100 IDE channel up to 2 ATAPI devices. Onboard 1 x 40-pin IDE connector
Expansive Slots: 1 x PCI slot.
Serial ATA interface: 2 x SATA interface support RAID 0/1
LAN Interface: 1 x AMD NetPHY 10/100Mbps PHY
Audio: Realtek ALC655A AC97 5.1CH Codec .
USB: 2 x USB 2.0 interface
I/O Ports: serial port, parallel port, IrDA, DB15 VGA port , PS/2 keyboard and mouse ports, SPDIF, IrDA .
Power Supply: Standard 20-pin ATX power supply
