Form Factor: Mini-ITX with 6.7 x 6.7 inches (17 x 17 cm) of dimension
Onboard embedded VIA C3 1.00GHz CPU.
DRAM: 1 x 184-pin DDR266/333/400 SDRAM up to 1 GB .
Chipset: VIA CN400 and VT8237
PCI Enhanced IDE: Two UltraATA/100 IDE channels up to 4 ATAPI.
I/O Ports: 4 x RS232C serial port, 4 x USB 2.0, 1 x DB15 VGA, 1x PS/2 keyboard and mouse ports
DVI Interface: Optional onboard DVI interface (667D)
TV-out Interface: Optional onboard SDTV/HDTV interface (667T)
LVDS Interface: Optional 18/24-bit LVDS interface with Mini-AGP add-on card.
IEE1394: 3 x IEEE1394 ports with VIA VT6306 MAC/PHY
GPIO Interface: Onboard programable 8-bit Digital I/O interface.
LAN Interface: 1 x VIA VT6103 10/100Mbps PHY, 1 x Realtek 8100B 10/100Mbps PCI controller
SSD: CompactFlash Type-II socket
Watchdog Timer: Winbond W83697UF with system generates 256 level reset
Expansive Interface: 1 x Slim PCI slot , 1 x Mini-AGP
Power Requirement: Standard 20-pin ATX power supply
