²úÆ·Ãû³Æ£º
LV-660
ÐÍ ºÅ£º
LV-660
Form Factor: Mini-ITX with 6.7 x 6.7 inches (17 x 17 cm) of dimension
Onboard embedded fan free VIA Eden 533 MHz CPU. Optional fan free Eden 400/800 MHz CPU for fan free application and C3 800/933 MHz CPU with onboard cooling fan for high computing capacity
DRAM: 1 GB PC100/133 SDRAM
PCI Enhanced IDE: dual Channels support 4 ATAPI devices up to UltraATA/100 with 100Mbps of data transfer rate
I/O Ports: 1 x RS232C serial port, parallel port, 4 USB, IrDA, PS/2 keyboard and mouse ports
Multi-media Interface: Chipset built-in Trident Blade3D SVGA with 8MB shared video memory and AC97 3D audio interfaces, optional AV and S-Video TV-out interface
LAN Interface: 10/100 Mbps Fast Ethernet interface
Expansive Interface: one PCI bus interface
