²úÆ·Ãû³Æ£º LV-651
ÐÍ ºÅ£º LV-651
Æ· ÅÆ£º ̨Íå¿Ïí®(COMMELL)
  • Form Factor: Mini-ITX from factor
  • CPU: Embedded AMD Geode LX800 Processor  .
  • MemoryOne 184-pin DIMM socket supports up to 1GB DDR SDRAM ,               Optional on board 256M DDR SDRAM
  • Chipset : AMD LX800 & CS5536
  • Real Time ClockChipset integrated RTC with onboard lithium battery
  • Watchdog Timer: Generates a system reset with internal timer for 1 ~ 255 sec (min)
  • VGA Interface: AMD Geode LX800 built-in high performance 2D Graphic ,          Supports CRT, 24-bit TFT LCD & 18/24-bit single channel LVDS LCD
  • Video Memory: Up to 256MB shared with system memory
  • PCI Enhanced IDEOne 44-pin IDE interface supports up to 2 ATAPI devices
  • Solid State Disk: IDE supports 44-Pin Disk On Module with +5V power supply,         One Compact Flash Type II
  • Audio InterfaceRealtek ALC203 AC97 Audio.
  • LAN Interface1 x Realtek RTL8110S-32 Gigabit Ethernet controller.
  • GPIO interfaceOnboard programmable 8-bit Digital I/O interface
  • Extended Interface: 1 x PCI slot, 1 x Mini-PCI socket.( the second PCI Bus master of PCI slot is shared with Mini-PCI )
  • Internal I/O Port :1 x RS232, 1 x RS232/422/485, 1 x GPIO, 1 x AUDIO, 1 x TFT, 1 x LVDS, 1 x Inverter, 1 x FDD, 1 x IrDA, 2 x USB2.0
  • External I/O Port: 1 x PS2, 1 x Audio, 1 x CRT, 1 x RJ45, 2 x USB2.0, 1 x LPT,          1 x IEEE1394, 1 x DC_IN
  • Power Requirement: Standard 20-pin ATX power supply or 8~24 full range DC input .
  • Dimension : 170mm x 170mm
  • Temperature : Operating within 0~60¡æ ,Storage within -20~85¡æ
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
