²úÆ·Ãû³Æ£º LV-650
ÐÍ ºÅ£º LV-650
Æ· ÅÆ£º ̨Íå¿Ïí®(COMMELL)
  • Form Factor: 17 x 17 cm Mini-ITX
  • CPU: onboard embedded AMD Geode GX1 300 MHz CPU   .
  •  Memory: Onboard optional 128MB SDRAM and one 168-pin DIMM socket supports additional 256 MB SDRAM.
  •  VGA Interface: AMD Geode CS5530A built-in VGA controller with 2D engine and 4 MB of video memory shared with system.
  •  Flat Panel Interface: Integrated 18-bit LVDS and TTL panel interface for TFT display.
  • Enhanced IDE: Dual Channels support 4 ATAPI devices up to Ultra DMA/33 with 33 Mbps of data transfer rate. One 40-pin and one 44-pin IDE Port for 2.5" notebook-size HDD, slim CD-ROM/DVD/CD-RW and cable free DOM (DiskOnModule).
  • Expansive Slots: 1 x ISA Slot , PC/104 Connector.
  • LAN Interface: 2 x 10/100BASE-Tx Fast Ethernet
  • Audio: Realtek ALC201A  audio interface.
  • USB: 2 x USB interface .
  • I/O Ports: 2 serial ports, 1 parallel port, IrDA, FDD, PS/2 keyboard and mouse ports.
  • Solid State Disk: On board CompactFlash Type-II socket.
  • Digital I/O: Supports 8 bit In/8 bit out digital I/O.
  • Watchdog: Software configurable, 1s.....255s / 1ms.....255 ms.
  • Power Supply: +12V only supply be used.
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
