²úÆ·Ãû³Æ£º LV-603
ÐÍ ºÅ£º LV-603
Æ· ÅÆ£º ̨Íå¿Ïí®(COMMELL)
  • Form Factor: Mini-ITX with 170 x 170 mm or 6.7 x 6.7 inches of dimension
  • Socket 370 supports Intel Pentium-III, Celeron, VIA C3 CPUs up to 1.3 GHz @ FSB 66/100/133 MHz, Intel FC-PGA2 Tualatin, FC-PGA Coppermine, PPGA CPU supported
  • Chipset: Intel 815E / ICH2
  • DRAM: 512 MB PC100/133 SDRAM
  • PCI Enhanced IDE: dual Channels support 4 ATAPI devices up to UltraATA/100 with 100Mbps of data transfer rate
  • I/O Ports: two RS232C serial port, parallel port, 4 USB, FDD, IrDA, PS/2 keyboard and mouse ports
  • VGA Interface: Intel 815E GMCH built-in 3D SVGA with dynamic video memory up to 64 MB shared with system memory
  • Audio Interface: AC97 3D 3D audio interfaces
  • Optional AV / S-video TV-out interfaces
  • LAN Interface: Intel PRO/100+ 10/100 Mbps Fast Ethernet
  • 1394 Interface: Lucent/Agere FW323 supports 100/200/400 Mbps of data transfer rate
  • Expansive Interface: one PCI bus interface
¹«Ë¾Ãû³Æ£º ÉϺ£Àø¿Òµç×ӿƼ¼ÓÐÏÞ¹«Ë¾
µç »°£º 021 51086209 / Íõ¼á
ÊÖ»ú£º 13916842198
µØ Ö·£º ÉϺ£ÊÐÑîÆÖÇøÖÐԭ·60Ū1ºÅÖÐÔ­´óÏÃ16²ã1601ÊÒ
ÓÊ ±à£º 200438
Ö÷ Ò³£º http://www.commell.cn
  • LE-379
  • LV-671
  • LV-670M
  • LV-671
  • LV-671Z
  • LV-67H
  • MP-6816D4
  • MPX-XDOM
  • LS-377
  • MPX-24794G
