Form Factor |
Industrial ATX Motherboard |
CPU |
Intel® CoreTM 2 Duo Desktop / Pentium D / Pentium 4 / Celeron D with LGA775 800/1066 MHz FSB. |
Memory |
4 x DDRII 533/667 MHz SDRAM t up to 3.0 GB |
Chipset |
Intel 945G and ICH7R |
Real Time Clock |
Intel ICH7R built-in RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset with 1 to 255 sec. / min. |
PCI Enhanced IDE |
One Ultra ATA/100 IDE channel up to 2 ATAPI devices |
VGA Interface |
Intel 945GVintegrated GMA 950 ( Graphics Media Accelerator ) Technology |
Video Memory |
Up to 224MB shared with system memory |
Serial ATA Interface |
4 x Serial ATA II Interface with 300MB/s transfer rate |
Audio Interface |
Realtek ALC880 HD Audio |
LAN Interface |
1 x Marvell E8053 PCIE Gigabit LAN |
Solid State Disk |
IDE 1 supports DiskOnModule with +5V power supply
1 x Compact Flash Socket
32-pin DIP JEDEC DiskOnChip Socket |
GPIO Interface |
Onboard programmable 8-bit Digital I/O interface |
Internal I/O Port |
1 x FDD, 4 x USB ports,1 x IrDA, 4 x RS232 & 1 x RS232 /422/485 serial port, 1 x SPDIF, 1 x GPIO |
External I/O Port |
1 x RJ45 LAN port, 1 x PS/2 keyboard / Mouse ports, 1 x DB15 VGA port, 1 x DB9 RS232 serial port, 1 x LPT, Audio, 4 x USB 2.0 ports |
Power Requirement |
Standard 24-pin ATX power connector ( 20-pin is compatible) Standard 8-pin 12V power Input connector (4 -pin is compatible) |
| Board Dimension |
307 x 244 mm (L x W) |
Operation Temperature |
0 ~ 60¡ãC (32 ~ 140¡ãF) |
