Form Factor |
Industrial Micro ATX Motherboard |
CPU |
Inte®l Core Duo / Core Solo / Core 2 Duo processor (Merom) with 533/667 MHz FSB. |
Memory |
2 x DDRII 533/667 MHz SDRAM t up to 3.0 GB |
Chipset |
Intel 945GME and ICH7M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset with 1 to 255 sec. / min. |
PCI Enhanced IDE |
One Ultra ATA/100 IDE channel up to 2 ATAPI devices |
VGA Interface |
Intel 945GMintegrated GMA 950 ( Graphics Media Accelerator ) Technology |
Video Memory |
Up to 224MB shared with system memory |
Serial ATA Interface |
2x Serial ATA Interface with 150 MB/s transfer rate |
Audio Interface |
Realtek ALC880 HD Audio |
LAN Interface |
2 x Intel 82573L Gigbit Ethernet controllers |
Solid State Disk |
IDE 1 supports DiskOnModule with +5V power supply
1 x Compact Flash Socket
32-pin DIP JEDEC DiskOnChip Socket |
GPIO Interface |
Onboard programmable 8-bit Digital I/O interface |
Internal I/O Port |
1 x FDD, 4 x USB ports,1 x IrDA, 4 x RS232 ports, 1 x SPDIF, 1 x GPIO , 1 x LPT , 1 x LVDS , 1 x LCD Inverter , 1 x CDIN |
External I/O Port |
2 x RJ45 LAN port , 1 x PS/2 keyboard / Mouse ports , 1 x DB15 VGA port , 1 x RS232 serial port , 1 x RS232/422/485 , 1 x LPT, Audio , 4 x USB |
Power Requirement |
Standard 24-pin ATX power connector ( 20-pin is compatible) |
| Board Dimension |
244 x 244 mm (L x W) |
Operation Temperature |
0 ~ 60¡ãC (32 ~ 140¡ãF) |
