Form Factor |
Mini-ITX Motherboard (170 x 170 mm) |
CPU |
Intel® Core™ 2 Duo (Merom) processor @ 800 MHz FSB |
Memory |
2 x DDR2 533/667 MHz SODIMM up to 3.0 GB |
Chipset |
Intel® GME965 & ICH8M |
Real Time Clock |
Chipset integrated RTC with onboard lithium battery |
Watchdog Timer |
Generates a system reset internal timer for 1sec/min ~ 255 sec/min |
Power Management |
ACPI 1.0 compliant, supports power saving mode |
PCI Enhanced IDE |
1 x Ultra ATA/33 IDE channel up to 2 ATAPI devices |
VGA Interface |
Intel® GME965 integrated GMA (Graphic Media Accelerator) X3100 Technology |
Video Memory |
Up to 384 MB shared with system memory |
Serial ATA Interface |
3 x Serial ATA II Interface with 300 MB/s transfer rate. |
Audio Interface |
Realtek ALC888 HD Audio |
LAN Interface |
2 x Intel® 82573L Gigabit Ethernet |
Solid State Disk |
IDE1 supports 44-pin DiskOnModule +5V power supply
CompactFlash Type-II on the solder side.
(CompactFlash shared with IDE bus) |
GPIO Interface |
Onboard programmable 8-bit digital I/O interface |
Extend Interface |
1 x PCI slot & 2 x Min-PCI socket |
External I/O Port |
2 x RJ45 LAN ports, 1 x DB15 VGA port,1 x PS/2 Keyboard / Mouse ports, 2 x IEEE 1394 ports, 4 x USB 2.0 ports, Audio, SPDIF, 1 x COM |
| Internal I/O Port |
1 x RS232/422/485, 1 x silm FDD, 1 x IrDA , 1 x LPT
4 x USB 2.0, 1 x 8-bit GPIO, 1 x Audio, 1 x CDIN
LVDS and LCD inverter connector, 2 x DVI, 1 x TV-out |
Power Requirement |
Standard 20-pin ATX power supply or
9V ~ 24V full range DC input (8 ~ 30V is operative) |
| Board Dimension |
170mm x 170 mm (L x W) |
Operation Temperature |
0 ~ 60ºC (32 ~ 140ºF) |
