| Form Factor |
Book-size Mini-ITX chassis |
| Construction |
Heavy-Duty steel |
| Mini-ITX Board |
Support:
LV-679D : Intel Core 2 Duo (Meron) @ 800 MHz FSB
LV-675 : Intel Pentium M / Celeron M
LV-669NC : VIA C7 1.5 GHz ( without CF on the solder side )
LV-667 : VIA C3 / Eden
LV-651 : AMD LX800 |
| Drive Bay |
External 1 x Slim CD-ROM Space
Internal 1 x 2.5" & 1 x 3.5" |
| Riser card |
2-slots PCI riser card |
| Thermal Control |
Two 5cm Fan side |
| Front Panel |
System Reset switch
Power On/Off and HDD activity . 2 x USB ports |
| Rear Side I/O |
Depend on Mini-ITX''s I/O Plate |
| Environment |
Operating Temperature: 0 ~ 40¡æ |
| Power supply |
90W DC Open Frame Power W/80W AC Adaptor (Optional) |
| Dimension |
273 x 300 x 65mm (D x W x H) |
| Weight |
2.22 kgw , (Case only) |
